4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....
Old 12-13-2015, 08:53 PM
  #501
Wolftrk99's Avatar
I need get my **** caught up.... Im ready for a damn lsa blower in my truck..... Damn it....yall are a bunch of bad influences
Old 12-20-2015, 11:18 PM
  #502
tgui's Avatar
Got a new vb gasket. Buttoned up again.
Waiting for a new oil pan gasket.
Old 12-20-2015, 11:24 PM
  #503
Wolftrk99's Avatar
Youre always waiting on something... Damn man!!!
Old 12-21-2015, 08:29 AM
  #504
tgui's Avatar
I know.... uhhggg.. frustrating!
Old 12-21-2015, 07:56 PM
  #505
tgui's Avatar
New pan gasket to replace the cork one. Now I can start putting things together again.
In total for this 1993 trans...
- all new seals, steels, frictions, bearings, bushings, and bands
- pump drilled to prevent front seal push out
- 2001 updated OD setup that's supposed to be stronger
- 36 element sprag
- internal dual feed
- direct drum drilled to prevent high rpm apply
- complete valve body rebuild
- Sonnax AFL valve kit using reamer
- Sonnax no push out case bushing
- torlon check bals
- pump rebuild with Sonnax parts
- custom linkage and NSS brackets, very exclusive, $$, pure art, sexy
- drain welded into pan
With Jakes, wolf, Atomic, gmc and others help I made a bastard child trans that I hope holds good power and lasts. 2nd times a charm, right?! I just wanted to doc in one place all that I did. It helps me deal with the pain of my truck in parts and being forced to drive my Lexus. Sigh, I need a late from whole foods to cope, and a manicure.
Tomorrow this goes on. Wednesday I start to put things back together. It's great I don't fear pulling this trans out again!
Old 12-21-2015, 09:48 PM
  #506
Wolftrk99's Avatar
A latte and a manicure?? Seriously??? about that man card.....
Old 12-21-2015, 10:10 PM
  #507
tgui's Avatar
Don't hate me because I'm beautiful.
Got the pan and xfer adapter on.
Old 12-21-2015, 10:15 PM
  #508
Wolftrk99's Avatar
If only you were female, would that apply!!!
Old 12-23-2015, 03:45 PM
  #509
tgui's Avatar
Just for this I'm posting even more mundane pics. And you've seen my face, I'm sexy.
Flexplate compare.
Jab a screw driver through a hole in the stock flexplate to lock it in place. The bolts are on tight.
No main seal leak! My pan is leaking though. I'll take care of that when I start the turbo part of the building when I need a oil pan drain.
In place. 3 rounds of tightening. 15ftlbs, 37ftlbs, 74ftlbs. Use blue loctite. My new bolts had thread locker already applied. Thanks TCI!!! Now I've fully shifted the weak point of the drive line to the diffs. Well, if the trans works this time.
Back under she goes!!! Too bad such a pretty trans will be hidden under a truck.
Old 12-24-2015, 06:40 PM
  #510
tgui's Avatar
Wolfy, had sagging exhaust like you. Added another hanger.
Got trans in, oil lines, so forth. 1/8 inch bit just fit. All good.
Quick Reply: 4l80e rebuild for 2002 Yukon Swap, SLOWWWWW BUILD....
