4l80e deep pan help!
Old Aug 19, 2014 | 12:36 AM
casper02's Avatar
Default 4l80e deep pan help!
So I purchased this B&M deep oil pan for my 4l80 only thing it didnt come with the extension I called B&M if they sold a replacement and to my luck it is discontinued now im stuck in my build anyone know someone who may sell a extension I can use or maybe a filter with a longer spout thanks in advance
Old Aug 19, 2014 | 09:53 AM
Jake's Performance's Avatar
FormerVendor
You can make an extension from aluminum bar stock with a lathe.
Old Aug 19, 2014 | 02:47 PM
casper02's Avatar
Any idea in the size the extension should be and what pipe to use
Old Aug 19, 2014 | 02:48 PM
casper02's Avatar
Would you be able to make one of these Jake ?
Old Aug 19, 2014 | 03:09 PM
Atomic's Avatar
I have a gauge for that
Thats really odd its discontinued since they still sell them with the extension included...part number of the pan is 70295, right?
Old Aug 19, 2014 | 05:17 PM
casper02's Avatar
I Believe so and just called summit and they dont have no extension in system only for 4l60 and 400 I think he said sucks cause its holding me fron closing the transmission
Old Aug 19, 2014 | 05:20 PM
casper02's Avatar
Would the 400 one work ??
Old Aug 19, 2014 | 06:00 PM
FormerVendor
We're really slammed with orders right now so we're running behind but I have some aluminum stock and could make one, just would have to find time to do so.
I would need to know how much added length you need for that pan. I can determine diameters from the filter.
Old Aug 19, 2014 | 09:12 PM
casper02's Avatar
I bet hell heard nothing from good things from your trans actually installing one of the overd assemblies with the bigger bearing you offer and what exactly would you need to know the height of the inside of the pan I have it at Tellez since they are building my trans and measurements you need and i can get for you Iwould really aappreciate if you can help my out
Old Aug 19, 2014 | 10:01 PM
FormerVendor
I just need to know how much it needs to drop the filter into the pan. I've used those things in the past but never looked at the dimensions. If it drops the filter 1" or 1.25" or whatever. I can make one and mock it up but I don't have the pan so don't know how much room I have. I may be able to make it "adjustable" to a point so they can cut it off as needed.
