4l80e from a 6.5
Old Oct 23, 2012 | 09:04 AM
loganlewis's Avatar
Default 4l80e from a 6.5
I located a 4l80e 4wd from a 97 Chevy 1 ton that was behind a 6.5 diesel. I know on hydraulically controlled transmissions the valve body needs to be swapped out because it relys on springs to shift. Since this trans is electronic, should I be able to use this valve body?
I know I am going to lose the top bell housing bolt but there are others who have done an older 4l80 into a newer ls truck. And being that it's a 97 has the correct harness plug and should have a neutral safety switch on the side.
So will that valve body work?
Old Oct 23, 2012 | 10:11 AM
slow67's Avatar
Gingervitis Addict
Yes, the valvebodies are the same between diesel and gas.
Old Oct 23, 2012 | 11:31 AM
nonnieselman's Avatar
your not gonna have the threaded bolt holes for the PN safety switch.. but yes it bolts up and will run.. just gonna have to build a small bracket for the switch.
Old Oct 23, 2012 | 11:43 AM
loganlewis's Avatar
Anyone got any pics for a home made bracket
Old Oct 23, 2012 | 12:30 PM
slow67's Avatar
Gingervitis Addict
Just use longer pan bolts, and make an "L" bracket on top of the pan rail.
Old Oct 23, 2012 | 01:42 PM
Your gonna have to use your imagination.. ive never seen one built.
Old Oct 23, 2012 | 10:36 PM
1FastBrick's Avatar
Custm2500's Rude Friend
How about this???
1997 Chevy Suburban 4L80e Transmission Swap Shifter Cable Bracket Photo 7
BTW that bracket shown is a factory GM part that is around $8 through a GM dealer. Other shops are selling it for around $20
GM part number 15013290
It should be the same bracket as your 4L60E if not at least you have the part number.
Old Oct 25, 2012 | 10:20 PM
Vince B's Avatar
No need to make a bracket. The 97-98 case has the bosses for the switch.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
RustyD
May 23, 2016 07:04 PM
AdaMax
May 16, 2016 11:35 PM
turbo6c3
Oct 5, 2015 06:11 PM
jscherbs
Sep 30, 2015 07:54 AM
