4l80 trans cooler lines
So trans getting about 200 after 30 mins of driving.
[IMG]
[/IMG]
I notice that both trans lines are right on top of header. kinda half *** wrap insulation around lines. Stupid question would header pipe get hot enough to heat trans fluid going into trans.
Do these lines need to be run a differn't path?
Can i just wrap these up better insulation? if so what kind?
[IMG]
[/IMG]I notice that both trans lines are right on top of header. kinda half *** wrap insulation around lines. Stupid question would header pipe get hot enough to heat trans fluid going into trans.
I feel like that wouldn't be enough to cause a significant rise in trans temps. The contact area with the header is pretty small and there is a LOT of fluid. Definitely get them off the header though. The lines are moderately flexible.
I ended up installing a tru cool 40K cooler. Works great.
highway temps 175
In town temps 160
wot 185
Cool down quite a bit. Install was very easy with brackets from time2kill on this forum.
highway temps 175
In town temps 160
wot 185
ferrellrooster
Jul 17, 2015 07:07 AM
