4l80 swap advise
Old Dec 31, 2015 | 05:14 AM
murderedSS's Avatar
Default 4l80 swap advise
Hey guys and gals I am doing a 4l80 swap ordered all my parts and the guy at patc said I needed the spacers for the crank shaft and a new flex plate? Thought I only need the spacers or a new flex plate? Can anyone shed some light on me
Old Dec 31, 2015 | 07:46 AM
1FastBrick's Avatar
Custm2500's Rude Friend
A crank spacer is required so the flexplate will reach the convertor.
It's like that from the factory on all the 01-09 LS based vehicles using the 4L80E transmission.
In 99-00 they had a special crank but in order to cut cost, they used a standard crank and a spacer to make up the difference so they didn't require a special crankshaft.
Old Dec 31, 2015 | 08:03 AM
Mr. Chainsaw's Avatar
you need both
Old Dec 31, 2015 | 08:56 AM
George C....'s Avatar
Formerly ScreamingL
You can use a 4l60 flexplate with a 60/80 converter which wont require any spacers
Old Dec 31, 2015 | 07:25 PM
zz454Chevelle67's Avatar
You will need both.
Old Dec 31, 2015 | 07:33 PM
EmmerichLSx's Avatar
formerly Emmerich 5.3 (2013-11-30)
Like he said, some converter builders can build you a converter that will work with your 80e and bolt up to your stock 3 bolt flex plate with no spacer.
Old Dec 31, 2015 | 07:46 PM
dirt track racer 81's Avatar
I've got tubular crossmembers if you need one.
Old Dec 31, 2015 | 07:47 PM
06 4.8's Avatar
Correct. Greg at Phoenix built my 80e converter to work with my stock flex plate
Old Dec 31, 2015 | 09:00 PM
Get one from this guy it's bad ***.
Old Jan 1, 2016 | 04:13 AM
BlueTexan24's Avatar
my circle D converter bolted up just fine without the spacer, but with the stock 80e converter I needed the spacer to get the converter spacing in spec.
