4l80 shift cable bracket where to buy
Old Jun 18, 2016 | 09:17 AM
murderedSS's Avatar
Default 4l80 shift cable bracket where to buy
Hey guys and gals I'm looking for a 4l80 shift cable bracket looked on line and can't find one I am swapping from a 65 to 80 and bought a brand new Trans and it didn't come with it thanks if anyone can help
Old Jun 18, 2016 | 12:35 PM
Wolftrk99's Avatar
Shift Cable Mount Bracket - 34913-01 - Sonnax
Theres this, or the dealer or maybe a junkyard...
Old Jun 18, 2016 | 12:40 PM
Wolftrk99's Avatar
SHIFT CONTROL/AUTOMATIC TRANSMISSION Part number 005 in the list $15
Old Jun 18, 2016 | 02:02 PM
1FastBrick's Avatar
Custm2500's Rude Friend
You mean this part number 15013290 which is listed in just about every 4L80E swap thread as well as my part number thread???
Incase you or anyone else's is looking for part numbers for a 4L80E swap. See post 3 of this thread https://www.performancetrucks.net/fo...thread-428941/
4L80E Conversion part numbers
#15765623 -Converter Dust Cover 6.0 W/ 4L80E
#11516328 -GM METRIC BOLT for lower cover to trans- M10X1.5X30 SOLD AS A SINGLE
#15724226 -GM METRIC BOLT W/stud Trans to Block- HFH,M8X1.25X20,M10X1.5X35 SOLD AS A SINGLE
#11515768 -GM METRIC BOLT lower cover to oil pan- M10X1.5X40MM,30MM THD SOLD AS A SINGLE
#12551367 -6.0 Flexplate
#12563532 -Crank Spacer
#12553332 -Flexplate bolts SOLD AS A SINGLE (6 required)
#15812049 -4L80E Front line near bell housing to radiator
#15812030 -4L80E Rear line return from external cooler
#24233366 -4L80E Front case fitting near bell housing 1/4-18 NPS THD
#24233367 -4L80E Rear case fitting goes into center support 1/4-18 NPS THD
#24205103 -4L80E AUX Fitting retainer clip SOLD AS A SINGLE
#15832205 -4L80E Dipstick tube
#15183801 -4L80E Dipstick
#15013290 -4L80E Shift cable bracket at transmission
#15251895 -4L80E Transmission mounted gear shift lever
#15724745 -4L80E 4x4 Transmission case adapter
#11589040 -4L60/65/70/80/85E Torque converter bolt SOLD AS A SINGLE (6 required)
#15767858 -80E Transmission mount same as 60E
Old Jun 18, 2016 | 02:08 PM
Wolftrk99's Avatar
Sorry bro forget about your pn thread.....
BLOWN 364
May 18, 2016 11:09 PM
montecarloss
May 10, 2016 08:07 AM
regency
Apr 11, 2016 07:25 AM
Jasinto78
Mar 30, 2016 07:20 PM
madmann26
Mar 21, 2016 05:56 AM
