4l80 output shaft help
Old Mar 24, 2013 | 02:49 PM
05_quick4door's Avatar
Default 4l80 output shaft help
What output shaft do I need?
Originally I though it was just a slip yoke but now I'm wondering because it looks like there is a bolt hole on the end of the output shaft
You can see the output shaft on the right. Long splines with no Oring
Then you can see the bolt hole here
I have no idea what year or model this came out of
Old Mar 24, 2013 | 02:50 PM
Heads-Up-Outlaw's Avatar
A slip yoke will work just fine with that shaft.
g
Old Mar 24, 2013 | 02:59 PM
Thanks
And the typical 6-7" th400 slip yoke will work right?
If I can only get the one that's like 3.5-4" long will be OK?
Old Mar 24, 2013 | 03:09 PM
Either one will work fine, but obviously the more spline to spline surface area you have the stronger it will be. The key is to make sure the over all drive shaft length is correct.
g
Blwn99x
Mar 24, 2023 11:14 AM
SloSVO
Nov 22, 2020 07:34 PM
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
StrokeTheLS
Sep 29, 2015 08:33 PM
Jaz
Sep 18, 2015 09:23 PM
