4l80 issues
Old Jan 26, 2015 | 06:47 PM
03sierraslt's Avatar
I am not familiar with that page. Is the ISS hooked up to the PCM?
Old Jan 26, 2015 | 07:20 PM
Turbostude's Avatar
Registered User
Which one? An 80 has two, correct? I unplugged the front one which I wired in for the 80/segment swap.
Old Jan 26, 2015 | 07:24 PM
Front is ISS, rear is VSS. So did you reverse the wiring you changed in the trans plug if you are trying to run the relay method?
Old Jan 26, 2015 | 07:34 PM
Turbostude's Avatar
Registered User
Yes, I reversed the wiring from the 80/segment then changed back to the 60/relay wiring. Then reloaded my 60 tune. I haven't driven it yet as the weather is bad, but I will as soon as possible.
Old Feb 4, 2015 | 04:48 PM
Turbostude's Avatar
Registered User
got to drive it today, still doing the same thing. I didnt try to shift it down into first at all, just drove it to my shop. seems like it stays in second for a long time, and when it does shift out, the convertor doesnt lock....
showing codes
P0740
P0785
P1860
Old Feb 4, 2015 | 09:40 PM
1bad2k's Avatar
showing codes
P0740
P0785
P1860
I know with relay method, the p0785 must be disabled, i think same story for the p1860. Ill have to look and make sure on that one. The p0740 i am unsure of though.
Old Feb 7, 2015 | 09:51 AM
Turbostude's Avatar
Registered User
I went in and deleted those DTC's, it will shift 1-2, but the 2-3 is sluggish and never goes into overdrive. Once in 3rd, it acts like the convertor is locking/unlocking, kinda like its slipping, or like its low on fluid. (Fluid is good) Are there other settings I need to change? I haven't done anything as far as the tune is concerned.
File Type: hpt
Idryfly5
Sep 2, 2022 08:55 PM
blownss27
Aug 14, 2020 08:27 AM
Texas5.3_1251
Mar 5, 2016 08:10 PM
ls1curt
Jan 5, 2016 11:33 AM
Alvin@PCMofNC
Sep 3, 2015 06:38 AM
