4L65E TC not locking in?
Old May 19, 2012 | 02:57 PM
0235SS93's Avatar
Default 4L65E TC not locking in?
I have a 4L65E with vette and billet servos behind my cam/heads lq4, and it has been faithful to me until now. The torque coverter wont lock in going down the highway. Ive double checked the settings for it in the tune and all looks fine...i recently switched to a shorter/wider tire, but I corrected the tire size in the tune. It should lock in at the tps % I hit while cruising at 60mph. I can manually lock it in with the vcm controls in my hptuners if I turn the tcc and pwm solenoids on. There are no misfire codes either. Any ideas on why the pcm isnt locking it in?
Old May 22, 2012 | 10:33 PM
3heartsurfer's Avatar
I battled this a bit and found a couple things that can keep it from locking. Disable/desensitize your misfire tables, and verify your tire height is correct by checking speed with GPS and use the calculator built into HPtuners to get it precise. Mine is dead nuts engaged at 43 mph every time now unless Im in the go pedal.
Old May 22, 2012 | 11:24 PM
0235SS93's Avatar
My speedo is dead nuts accurate as confirmed by a tomtom and a garmin gps. Maybe it has to do with the cam and misfires, idk?!?
Old May 23, 2012 | 12:34 AM
oakley6575's Avatar
I had to max out my idle misfire tables to get my tcc to lock.
Old May 23, 2012 | 12:43 PM
0235SS93's Avatar
I just set the enable temp under the misfire tab to 250* just to see real quick and sure enough, the converter locks in now! So what tables should I mess with and how do I go about "de-sensitizing" them to fix it right?
Old May 23, 2012 | 03:48 PM
oakley6575's Avatar
Just max out the two idle misfire tables. Moving and non moving. It should lock like it should after that.
Old May 23, 2012 | 10:21 PM
0235SS93's Avatar
Ok thanks!!
Alco
Jul 20, 2016 04:53 PM
bearden86
26
Nov 15, 2015 03:58 PM
dsbodley
Nov 14, 2015 09:46 PM
Cammed4ever
Sep 30, 2015 03:38 PM
JoshH
Sep 28, 2015 11:19 AM
