4L65-e Capacity..........
That's awesome! Any idea what your truck weighs? 4400 or so? My truck weighs 5500 with me in it across a certified truck scale.
I ran a used 80e for 2 1/2 years, bone stock. I drive 30-35k per year. Ran the #s in sig with it. The clutches started slipping and I had a friend rebuild it to stock specs and put a shift kit in. If you look at the internals of a 60e vs an 80e you will understand why they can handle the more power with ease.
I too have a 65e and I think I will do a 80e swap. I broke a fully built 65e and dont want to flush the coin down the drain with another one....plus I plan on a turbo down the road.
Your truck & my truck are similar in size & weight, and I've had "some trouble" getting any 4L60E to live with my 5.3/Maggie combo. I'm sure more cubes & a bigger blower would just make it break more frequently.
You should consider the 80E swap. I'm already starting to collect parts.
If you are planning on such an engine then trying to go with a 4L65E is like trying to reinforce a wet paper bag. A stock 80E with only a shift kit should be good for 600-700 hp I would think. Mine had tons of trash in the pan and 130k on it when I put it in but it has still worked great and I have tried to break it. I'm not making that much power, maybe 400 if I'm lucky but so far even with a weak direct clutch it still has not let me down. Hard parts are available to make them hold into the 1200 range, maybe more.
