4L65 or 4L80?
Old Dec 8, 2005 | 08:15 PM
  #41
James you have a heavy truck with alot of power you need an 80e and a 3K stall should fit the bill perfect. Like I said I have pulled the trans 3 times and it aint fun for sure. Are you 2wd or 4wd?
4WD and 5500lbs. That ECSB is a heavy bugger. Do you think I can tow with a 3K stall or should I go 2800.
Old Dec 8, 2005 | 11:01 PM
  #42
Bad_Apple's Avatar
Well I got PM from Dave at Rock-On he told me some stuff about his level 5 4L60e, and I believe it should be good enough to go threw the hell I put on one. I want to bump my stall up to 3200 to help my 60ft. some, and I believe that level 5 should hold me for a while. Now its time for the fun part saving up and see if I can tell the fokes Santa needs to be packing a built 4L60 under the tree this year. hahaa
Old Dec 9, 2005 | 08:01 AM
  #43
dewmanshu's Avatar
Moderately Differentiated
Before I decided to go 80e, my 60e and a Yank 3000 did fine. It would get up in temps if you are towing in alot of stop and go areas. But did just fine. I now have a 2800 in the 80e. It's different...but it works great for towing as well. It's a preference thing, as long as you have a cam that can make something out of a 3K stall (or vice a versa) it would be a preference thing.
Good luck! If you every do lose it...I really hope you don't...again, I have a 60e in the shed freshly rebuilt I'll sell ya! Seriously though...good luck. No matter how you look at it, driving a truck that hauls *** is fun.
Old Dec 11, 2005 | 10:30 AM
  #44
DrX's Avatar
DrX
Some more info on the 60/65Es:
Edit: non sponsor link
Down the page they don't seem to think that a built 60/65 is suitable for FI heavy trucks(Tahoe is mentioned). Although they do say that they expect to have a 1000 hp rated 60 soon.
Old Dec 11, 2005 | 10:36 AM
  #45
DrX's Avatar
DrX
What does the Level 5 include over the Level 4 shown on their site?
Old Dec 11, 2005 | 12:00 PM
  #46
Bad_Apple's Avatar
This is what Dave told me from Rock-On, "Our level 4 can handle what your doing. Our level 5 is 2145.00 and has a billett pump and hardened shafts, It basically can handle alot more hp. without the front pump issues. Our level 5 has a billett rotor to handle the fliud pressure and extreams thrown at it by nitrous. Also helps with boosted pressure". I believe that will be the trans for me. I would like to have a 80e but I dont fell like buying new converter and swapping all harnesses, and getting retuned. He said its pretty badass 4L60, and with a 3200 stall it would be the perfect setup for the Procharger.
Old Dec 18, 2005 | 08:57 PM
  #47
Well Im leaning towards the Yank TT2800 for the 4l80. Any thoughts before I purchase?
Old Jan 15, 2006 | 07:14 AM
  #48
cablebandit's Avatar
9 Second Club
While RockOn is building my 4l80e, i am running a th-400. I had a built 4l60e. I mention the th-400 because it has the same gearset as a 4l80e and we can compare times. My car lost NO ET with the 400 vs the 4l60e. I was surprised but i THINK that its because I am turbo'd. The 3.06 vs 2.48 1st gear is the main difference. The turbos like load and I think the 2.48 first gear helps me build boost faster and thats why i didnt lose any time at the track. Also...with the 4l60e I had a 3200-3800 stall (tried 3 different converters)...in the th-400, i have a 2800 stall. Now gas mileage...of course i lost 2-3mpg on the highway due to no O/D..in town I lost 4-5 mpg!!!!! Again i think its due to that 1st gear. Just some info to ponder...
Old Jan 15, 2006 | 09:04 PM
  #49
Thats good information. I figured with a 2800stall converter which is 20lbs less than the stock converter there would be some tradeoffs. Does anyone know what the 4l80 stock converter stalls at?
Old Jan 15, 2006 | 09:23 PM
  #50
quicksilverado's Avatar
2000, the 2800 worked great for me. I had to throw the stock one back in because I burnt up the clutches in the Art Carr 2800. It is only 9 1/2 inches in diameter so it does not have alot of clutch surface. I'm gonna see if they can put better clutches in it.
