4l60e noise
Old Sep 19, 2013 | 08:26 AM
D-WAKE's Avatar
Default 4l60e noise
Truck is a 02 sierra 5.3 113k stock..
I'm getting a ticking noise under load. At idle and in park reving it it's not there. When I get into 2,000 rpms it starts and stays till I let off the gas. Sounds like its going to explode when I floor it but it hasn't yet and I'm just wondering if anyone has an idea of what it is?
http://youtu.be/9Mh35hTr81o tried to make a video of the sound.
Old Sep 19, 2013 | 09:18 AM
CMAR81's Avatar
Had an issue similar to this....in my case torque converter bolts backed out..new bolts thread lock and about 20 min. Good as new.
Good luck
Old Sep 19, 2013 | 11:20 AM
D-WAKE's Avatar
Good luck
Yeah that was the first thing I checked I pulled off the bottom cover and spun it and I didn't see any of them backing out.
Old Sep 21, 2013 | 12:15 PM
James B.'s Avatar
Drop the pan and look for metal. Suspect would captive needle bearing failure in the front planet. No way to tell for sure without a complete teardown, but if that is on it's way out it will take the drum, output shaft and planet carrier with it eventually if not corrected.
I personally would not drive it like that until at least the pan is inspected.
Old Sep 23, 2013 | 10:41 PM
performabuilt's Avatar
LS1TECH & Trucks Sponsor
Check that the converter bolts and or flex plate are not contacting the back of the engine due to either a cracked or damaged flex plate or excessive engine thrust bearing clearance
Old Sep 24, 2013 | 06:58 PM
D-WAKE's Avatar
Good news I found it! It was the plastic cover that's goes under the starter. It was broke and kept hitting the torque converter bolts. ... But now it has a ticking noise coming from the motor sounds like a collapsed lifter!?! It's there in park which is completely new...
Wolftrk99
Dec 3, 2015 08:12 PM
lukn4trbl355
Oct 21, 2015 11:19 PM
Infernohoe
48
Oct 2, 2015 10:25 PM
Velocity1
Oct 2, 2015 08:01 AM
tim wellington
Sep 29, 2015 10:17 PM
