4l60e no 4th gear shift please help
Old Nov 11, 2011 | 09:47 AM
chevyracer8262's Avatar
Default 4l60e no 4th gear shift please help
I just completed my 01 lm7/4l60e conversion and I'm having a shifting issue with my trans it shifts great for the 1-2 and 2-3 shifts even locks up at45-40 mph bit I have no 3-4 shift any ideas or suggestions? I rebuild the trans myself and have a few ideas of the cause I'm just trying to eleminate anything electrical before dropping the pan..
Old Nov 11, 2011 | 11:48 AM
chpspecial's Avatar
I just went trough this my self. a few months back I lost 4th. Fluid was fine, all other gears shifted perfect and at the right times. The PCM was comanding 4th apply but I was not seeing it. it just stayed in 3rd. NO signs of slipping components either. And because i had a proper 2nd gear, I narrowed it down to a bad 4th apply servo. The only difference between a 2nd and 4th gear shift is the servo. So if you do not have 4th, and only 4th with no other problems, then your 4th gear servo is fubar.
I pulled mine out last night and sure enough, my servo was seized. Put a stock one back in and all is perfect again... so now onto ordering new billet servos.
Old Nov 11, 2011 | 06:19 PM
Vince B's Avatar
What did you use for the 4th gear servo? Also if you installed a transgo shift kit I would verify that you installed the 3-2 downshift valve spring in the correct location. I have seen guys get confused and install it in the 3-4 relay valve bore and not have 4th gear. I do not think that you have an electrical issue because you have first gear. The same solenoid used for 1st comes on in 4th as well. Vince
ferrellrooster
Mar 6, 2025 03:22 PM
Jakejack
Jan 8, 2024 10:44 PM
Oobray
Jun 13, 2022 03:38 AM
Ferocity02
Aug 7, 2015 08:50 PM
