4L60E........no 3rd or 4th Gear
#22
So i found. that the little spring clips in the 3-4 clutch were upside down and the metal clutch plates in the 3-4 were to small......so hopefully replacing and fixing these probelms will get my 3 and 4 gears back.
#23
Originally Posted by gonzo 6.0
Trey
Did you get kissed too while they were f*ckn ya.How could you let that happen?
I didn't have a choice. my rent was up at school and I was trying to get going.
I had no way of diagnosing it. didn't have much say in the issue
#27
It is true,they say remove them,some 3-4 clutch makers say leave it or some.Not a seriouse item.If you air checked 3-4 why didnt you see there was a problem? With the problems/mistakes you have found you are making it will be a miracle this thing works properly.no offense good luck.Did you figure it out or did you bring someone else in?
#28
when i air chefked the assembly the first time....it still worked the say way that it would if they were positoned different....it made no difference....not to mention this is my first time overhauling a transmission...and the manauls i have are crap....and don't explain very well. i figured the spring thing out just by looking at what went wrong.
