4L60E internal wiring harness
Old Apr 4, 2009 | 08:02 PM
CashDudeHomie's Avatar
Default 4L60E internal wiring harness
Can it be replaced without dropping the valve body?
The salvaged 4L60E I bought had some of the plastic tabs on the round plug slightly damaged and the plug was loose. I popped it back up into place and it seems to be secure, but if it leaks or falls back in, I will need to replace it.
Thanks for any ideas.
Old Apr 4, 2009 | 09:51 PM
FLT's Avatar
FLT
FormerVendor
Yes the harness can be replaced without removing the valve body. You would need to remove the 1-2 accumulator housing, the epc solenoid and the pwm lockup solenoid in order to do it. I have also seen a bracket from sonnax that can be used to salvage a harness that is damaged like yours. Vince
Old Apr 6, 2009 | 02:41 AM
Awesome. The Sonnax bracket is only 2 dollars and I had never even heard of it. Thanks for the great info Vince!!
D1SCSS
Jan 25, 2016 10:14 PM
TimDave217
Aug 24, 2015 04:38 PM
smokeshow
Aug 23, 2015 08:23 PM
vortecyota
Jul 23, 2015 08:26 PM
