4l60e acting weird
about a month ago i changed the fluid and filter in the tranny on my 94 k1500, and added a b&m shift plus(or as i call it now shit plus). while im cruising between 45 and 60 mph, it for lack of a better way to describe it, slips. it shifts fine but while im driving the rpms change by just a very little amount fast and slow. it didn't do it before i changed the fluid. i do have 33s on it and 3.42 gears, but they've been on it for years. any thoughts?
i have that same kit and it was ok at first then i added a vett servo and it would bang the 1-2 shift at light throttle and 2-3 shift but if a was hard on the trottle it would do fine . so i just turned it to the off side. and stopped running it when around town i use stage one when towing and shifts nice when towing just not good when daily driving at light throttle .
its not so much the shifting im concerned with. its the constant change in rpms when im at part throttle from 45-60 mph.
3/4 might be going out. that rpm change is really noticalble when you have non sock exhaust. IF you just drive it in 3 does it do the same? Do you have a trans temp guage? It could be several other things as well.
If you had never changed your fluid until now all the "stuff/gunk" is now gone and theres is more free space between your steels and clutches. I would predict you have a tranny rebuild in your future. My last truck i had the 60e rebuilt a total of about 6 times. I am not a stranger to slipping trans. Have you checked your fluid level? The rpm changes is the clutches slipping. I bet that if you put it in cruise control it still will have the rpm changes. Eventually our steels will over heat, warp and your down. |
could be many things even a torque converter clutch sliping of locking and unlocking
TCC solonoid as well, the valve body might be closed or even a stuck check ball in your trans like in my old 60e trans.
If you need to replace the solonoids buy oem only. https://www.performancetrucks.net/fo...9&d=1273268999 https://www.performancetrucks.net/fo...0&d=1273268999 |
ill try to get video of it tomorrow. im planning swaping a newer one when i do the 6.0 swap anyways. i just need to get this one to last til then. fluid level is good, a little foamy. i think it was always like that though.
put in a bottle of the lucas stuff for slipping trans. its thick and might help keep it up and running for a while.
foamy ? could be over filld
So it doesn't do it in just 3rd. And every now and then when I park and get out I can smell tranny fluid. It doesn't leak, but I can noticeably smell it.
