4l60e 65e 70e technical thread, cooler install codes, diagrams more!
Old Sep 3, 2009 | 02:25 AM
  #41
fastgmc98's Avatar
Would you happen to have the wiring schematic for the PRNDL switch (12pin connector) located on driver side of a 2005 2WD Silverado w/ 4L60E trans? Original harness and connector damaged beyond repair, bought new harness w/connector but can't figure out where they get connected to or which Pins on PCM they get pinned into...
Thanks in advance
Old Feb 20, 2010 | 07:01 AM
  #42
LARRY01Z28's Avatar
Very good read. Thank you
Old Sep 24, 2011 | 03:07 PM
  #43
mhotrodscooter's Avatar
Why isn't this a sticky???
Old Sep 25, 2011 | 10:33 PM
  #44
nonnieselman's Avatar
I wanna figure out how to manually lock the TC in a 60e. In my samurai id like to have a switch on the dash to lock the TC while riding in sand so it wont be slipping all the time in 2nd.
Old Sep 25, 2011 | 10:47 PM
  #45
Vince B's Avatar
Thats easy. Grab the gound signal wire off the lockup solenoid in the pump. Then put a toggle switch on it and tag it to ground.
Old Sep 25, 2011 | 10:48 PM
  #46
Vince B's Avatar
Done!
Old Sep 26, 2011 | 01:14 PM
  #47
budhayes3's Avatar
PT's Slowest Truck
Originally Posted by Vince B
Done!
Good job brotha
I put a lockup switch in my 85 MonteSS with the 200R4, after my trans was "built" for the second time by a trans builder who used to have a good rep, but I guess since he wasn't the guy who built my unit I ended up with a hack.
The trans was acting real funny and I stopped by their shop for a test drive and it blew up on the road and they had to give me a ride home...IIRC, I didn't even have 100 miles on the unit after they built it. They did a shitty job with the install too...bent my hood and exhaust, I was pissed... (the first time around I pulled the trans and sent it to them, but since I broke down at their place, they did the swap and rebuild for me).
Anyway, the thing would go into lockup too soon and lug like ****, so I tapped into the brake light switch (which I know that Vince knows, and others may too that applying the brake releases the TCC), and put a toggle switch that I'd just turn on when I was cruising and TCC operation was beneficial. Around town, the switch pretty much stayed turned off. But yea, it was a piece of cake
Old Oct 31, 2011 | 03:28 AM
  #48
N/ALS1's Avatar
This is one informative thread.
Old Apr 1, 2012 | 05:30 AM
  #49
the demonik's Avatar
nice info.
Old Apr 1, 2012 | 11:29 AM
  #50
Petey62782's Avatar
MASS seller approved
Wow what a great write up
