-   GM Drivetrain & Suspension (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/)
-   -   4l60e 4x4 output seal (https://www.performancetrucks.net/forums/gm-drivetrain-suspension-22/4l60e-4x4-output-seal-531301/)
truckmann Aug 8, 2014 06:05 PM
2 Attachment(s)
2003 silverado 4l60e 4wd. I took out the transfer case because it was leaking between the transfer case and transmission. The fluid is red so I'm assuming its transmission fluid. Am I right to assume there is not an easily serviceable seal on the output shaft and that the only thing keeping the fluid in there is the seals on the adapter?
Attachment 100487
Attachment 100488
GMCSIERRA5.3 Aug 8, 2014 07:35 PM
Only a orange seal on the case and from tailhousing to transfer case theres the gasket thats it
truckmann Aug 8, 2014 08:10 PM
That's what I thought. Thanks.
The nuts holding on the t case were a bit loose, so hopefully that explains the leak.
built408 Aug 11, 2014 07:26 AM
A driveline vibration will cause the nuts to back off.
truckmann Aug 11, 2014 09:21 AM
Makes sense. I had to replace the rear u-joint a couple of months ago.
Flmann407 Feb 25, 2022 07:23 PM
So there's no output shaft seal on this style then correct just ext. Paper gasket and the rubber ring bolt seals keeps fluids in .. my transmisson shifts fine just losing fluid
