4.8l 5speeds
Old May 15, 2006 | 10:07 AM
  #21
vanillagorilla's Avatar
Originally Posted by mjhoward
Yeap, them 5 speeds are weak as hell.
Don't you have the newer 5spd though? I thought they had a redesign in 03 or something with yours being the stronger of the two. I don't think they can be any weaker than a stock or mildly modified 60E though. I know the T56 is a poop-ton stronger.
Old May 15, 2006 | 10:25 AM
  #22
TurboGibbs's Avatar
Mine is the tremec TR-3450. I am unsure of when they swaped over. My 95 has the NV3500 and has 170k miles on it and has held up to my 383 with 150hp shot on it a few times, power-shifting (that is not letting off the gas when you shift). I've never had slicks on it though. I did replace the front brg in it at 69k miles. That is basically all I've done to it.
Old Mar 15, 2007 | 12:54 AM
  #23
anarchyracing101's Avatar
Originally Posted by anarchyracing101
1999 4x4, 4.8, stock ported throttle body, throttle body bypass, custom ram/air duct on passenger side made of aircraft sheetmetal, k&n filter, asp pulley, predator handheld, flexalite fans, true dual str8 piped exhaust w/x pipe......need to instal the spec stage 2+ clutch this weekend
future holds some L/T's, a cam and a magnacharger, just working the motor up to it!
wow that post of mine is old news!....so far mines a 6.0 lq4 running n/a cammed with pacesetters for now til i get all my turbo part together.Ive been runnin on the nv3500 for 3 years. I use the 4wd in the winter otherwise id have a t56........ swapped in the 6.0 last summer im only on my 2nd nv3500. theyr strong at first but not strong enough.
Old Mar 15, 2007 | 05:35 PM
  #24
Red04Silverado's Avatar
04 Reg Cab Step Side here with a 5speed. I have the Hurst shifter on my truck. I love it!!!!!
Old Mar 15, 2007 | 06:55 PM
  #25
sschevy0205's Avatar
The TR3450 is that the same tranny and clutch and internals as on the 05 4.3l v6,if so can the Hurst short shifter work on the v6 aswell
Old Jun 28, 2016 | 12:15 PM
  #26
_zebra's Avatar
makes children cry
super-old bump, but i just figured i'd chime with my bolt-on 5.3 nv3500 4x4. running 33s with a TrueTrac, 4.30s, and a Hurst shifter. bought it in Nov '06 & still going strong with almost 213k on the clock.
Tydriver
45
Oct 23, 2015 09:19 PM
lycominghunter
26
Sep 25, 2015 07:50 AM
Big_pimie
Sep 22, 2015 09:07 PM
