4:88 gears?
Old Jun 9, 2010 | 06:50 PM
skeet's Avatar
Originally Posted by jophuss36
Let us know how u like em skeet!!
why of course
Originally Posted by 1Bear
I’m mixed on my feelings toward lower gears in our trucks, or at least in my case with a Magnacharger. I had the gears 1st and if it were the other way around, I probably wouldn’t have gone that far. With the low 1st gear and the overabundance of low end torque, it will just blow through 1st. I do wish I were turning a couple of hundred rpm’s less on the highway as well, but overall it’s not bad, I’m turning about 2300rpm or so at 70mph and still only 2500rpm at 80mph. Now if I had a 4L80 with a higher 1st and better overall gear spacing, I’m sure I would like the 4.56’s better, but then I would end up turning a little higher rpm on the highway. It’s almost a damned if you do, damned if you don’t situation, especially with a supercharged 6.0. However with a smaller less torque’y motor, I wouldn't hesitate at all to run a deeper gear. I know we all look at one another’s set-up’s to get ideas, but in reality everyone’s combination is different and as such will have to be looked at individually.
I have a friend that has a 4.8 equipped SCSB with cam on a 110cl that is in terrible need of a converter, but he chose to do gears 1st, going from 3.23’s all the way to 4.56’s and as you can imagine it helped his take off’s immensely and at least made it half-*** enjoyable to drive again.
4:56s should help you since your magnacharger ( i would think ) if youre putting the horsepower down, ( lots of torque ) then a stall and gears would be your friend the problem would be figuring how to get it to hook.. full slicks on the track and a goos suspension and you'll have lower numbers foresure
Old Jun 9, 2010 | 07:00 PM
00ChevyScott's Avatar
Wearin' da big hat
Aren't you guys afraid that the smaller pinion gear will break with all this power?
Old Jun 9, 2010 | 07:05 PM
dlt76028's Avatar
FI likes taller gears to have something to "pull" against. If I had a magnacharger I would have 3.42s or 3.73s.
Old Jun 9, 2010 | 07:57 PM
MPFD's Avatar
11 Second Truck Club
There's alota 1/8 mile guys out there going 5.13's. Talk about a little pinion..
Old Jun 9, 2010 | 08:24 PM
jophuss36's Avatar
O you guys think going to 488 gears would stop my tramsmisson problems? I've gone threw 6 of them sometes hardparts sometimes not
Old Jun 9, 2010 | 08:37 PM
MPFD's Avatar
no, might be better... Thats alota power your trying to put down on 35" tire...
Old Jun 9, 2010 | 08:49 PM
05RST2NV's Avatar
Thats true, dang near all the big LS1 turbo cars ive seen run 3:42s and 3:73s
Old Jun 9, 2010 | 09:13 PM
jophuss36's Avatar
Yaw thsts wjat I'm thinking too . I'm just trying to think if I have any alternatives to taking a 3 grand loan out for an 80e swap
Idryfly5
Sep 2, 2022 08:55 PM
Oobray
Jun 13, 2022 03:38 AM
blownss27
Aug 14, 2020 08:27 AM
jtphelps289
Sep 29, 2015 12:00 PM
Cowboy Tom
Sep 5, 2015 04:29 PM
