4 to 6 speed swap driveshaft question
Going from a 60e to 6l90e trans and am kinda curious if I can reuse my stock drive shaft? I know the slip yokes are different so that will be changed. The 60e and 90e case lengths are basically the same from what I could come up with.
Any help is appreciated guys
2 wheel drive btw
2 wheel drive btw
Found this from iamkeniff
swap
"if you are running a stock 1 peice that came in the truck all you need is a 1350 to 1350 u-joint."
Anyone else have any experience? Just want to make double sure the drive shaft doesn't need length modification
swap
tgui
Aug 11, 2015 08:30 AM
