3.73s or 4.10s
Old Jun 10, 2007 | 01:09 PM
nightrunner's Avatar
Mr. Obvious
Originally Posted by RandomHero
You have 3.23's they never put 3.08's in a 99-07 truck
Old Jun 10, 2007 | 05:25 PM
sbw9056's Avatar
The original tires you had on your truck were 30.46". Your new tires are 30.49". You don't need to recalculate your new gear ratio for tire size.
Old Jun 10, 2007 | 05:33 PM
regency's Avatar
go with the 4.10's because there is no real difference in how they perform from a 3.73!!! my truck originally had 3.73's and i swapped them over to 4.11's and noticed nothing.
SENT YOU A PM MAN
Old Jun 10, 2007 | 06:23 PM
skyhighsami's Avatar
no title here
Where in the VIN does it say what gears I have and if I have the locking rear end of not? I know that when the truck spins it does spin both tires so I think it has a locker but I would like to know for sure. Thanks
Old Jun 10, 2007 | 06:25 PM
speedy02's Avatar
4:10's FTW!!
Old Jun 10, 2007 | 06:30 PM
4.10's. Your truck is heavy.
Old Jun 10, 2007 | 07:16 PM
GTOsRamairSilverado's Avatar
G80 - Locking Rear Differential
GT4 - 3.73 Rear Axle Gear Ratio
GT5 - 4.10 Rear Axle Gear Ratio
HC2 - 2.76 Rear Axle Gear Ratio
HC4 - 4.56 Rear Axle Gear Ratio
HC8 - 3.21 Rear Axle Gear Ratio
HE3 - 3.07 Rear Axle Gear Ratio
HO4 - 4.11 Rear Axle Gear Ratio
Look for those numbers on the sticker in your glove box.
Old Jun 11, 2007 | 08:53 AM
no title here
I drove with the truck in OD today and watched the RPMs. It looked like I was running around 1500 or so. So that makes me think that I have a 3.23, I don't know for what reason I was thinking I has a 3.08. Anyway so going from a 3.23 to a 3.73 I don't think will make enough difference, so I will be looking at going 4.11 if I do anything. I will see how much harder it will come out of the hole after the headers and the tune. I think that the TM is hurting it more than anything. It is a slug out of the hole.
Old Jun 11, 2007 | 08:59 AM
.T.'s Avatar
.T.
cant go wrong either way...i would do the 4.10's in a crewcab
Old Jun 11, 2007 | 09:08 AM
treyZ28's Avatar
3.73s imo.
