2wd conversion
Old Dec 14, 2008 | 11:13 AM
ajt86's Avatar
Default 2wd conversion
hey guys
i have a 2004 tahoe with a 4/6 drop and the front diff has sprung some leaks from the insanse drive shaft angles. i have only ever used 4wd once so i dont really need it i was wondering if anyone has a write up on how to remove it? i know how to pull the front diff, axles, t case, install a 2wd case extension on the transmission and swap to a 2wd drive shaft, but what about the electronics. if i remove the stuff the 4wd light will go on, if i pull the TCCM it will go on- is there anyway to make it so the service 4wd lights dont come on? anything else i should know?
Andrew
Old Dec 14, 2008 | 11:31 AM
tarinitup's Avatar
9 Second Truck Club
Wouldn't it be easier to fix the leak than do all that stuff?
Old Dec 14, 2008 | 11:56 AM
ajt86's Avatar
the leak isnt the big deal, i just know its only been about 3000 miles and with these extream angles im going to be dealing with alot of problems with a system i dont use, i want to go to a 4.10 gear but currently dont want to deal with doing gears in the front/and read, and it will be nice to loose the weight of the diff/axles/and Tcase
Old Dec 14, 2008 | 05:09 PM
tarinitup's Avatar
9 Second Truck Club
Alright good luck then. I'm liking the springs you sold me.
Old Dec 15, 2008 | 09:25 PM
silveradol33's Avatar
how about take out the diff, and then put dummys in to hold the wheel bearings together. Pull the front prop shaft and call it a day, I see no point in wasting money and time to pull the case, flash the pcm to 2wd version and all the bullshit to make it 2wd. Would be a cheap and easy way to do it, its up to you tho. Good luck.
Old Dec 15, 2008 | 10:04 PM
you shouldn't get a light I didnt atleast, however, you do need 2wd front hubs.
BROKE-aSS-BLAZER
Oct 13, 2017 03:50 PM
Silver8ado
Sep 30, 2015 11:42 AM
Rockrz
Sep 29, 2015 09:07 AM
trxmxzx
Sep 29, 2015 07:42 AM
bisqikss
Sep 27, 2015 09:40 PM
