2002 tahoe with djm lowering kit question?
I installed the DJM 2/3 inch drop in my tahoe. The front was the torsion bar keys and the rear was the springs with the shock extenders. After the drop i went ahead and got a wheel alignment. This is where the tragic starts.... before i explain the issue please understand the truck was all original and never in an accident.
The wheel alignment tech who is actually someone i know couldnt get the passenger wheel straight. It was set to the max and he couldnt get out of all the negative camber it had. The drivers side was actually straight and looked perfect but as for the passenger side it looked like it was running on the inner side of the tire which of course it was. After messing around and taking alot of his time i gave up and went home to look at it myself and go over it. I was able to crank the torsion bars up a little to give me more postive camber but still not enough. If i go up anymore the front of the truck will be higher then the rear.
Why is this and is there a solution. I really dont understand why this is happenning even with a small drop!! Should i have gone with the front spindles instead? Before and after shots.
You need to understand how the suspension works with a torsion bar setup. You are turning the torsion bar to pivot the suspension up to get you're drop. By doing that you affect the camber and limit the amount you can adjust it to get back to 0. I went through alot of lowering kits on my wife's Yukon XL. I had a Springtech 2-3 then a DJM 3-5 and finally Belltech spindles, Belltech 5305 coils with helper bags. So I'm talking from first hand experience. Take the keys off, get some spindles and then adjust your final height with your torsion bars with stock keys. If you go more than 3" on the back you have to get the rear hardware kit from DJM. The Belltech coils in the rear are the best possible thing you can get. I tried 4 different sets and they were the best. The helper bags run such a low pressure usually around 5-10 psi that they are more of an intermediate bumpstop. I also tried several shocks and the absolute best was the Bilstien HD. Our Yukon finally sat about 4-6 which rode great, almost tucked a 305/40/22 and towed alot of weight with just a little air in the bags. PM me if you need any further help. I redid ours alot and have lowered about 3-4 more.
The DJM keys are re-indexed to allow the drop without turning the keys way down. They are "supposed" to allow you to install them at factory suspension specs and it be 2" lower. I personally am not a fan of replacing the keys because usually I have been able to swap the coils out in the back and turn the factory keys to make the truck sit some what level or have an inch or so of rake and never had any alignment issues. On my wife's truck I did keys, LCA, and finally spindles. On the keys I was able to get it aligned. The lower control arms it was just like yours, the adjustment was maxed out on one side so the other was adjusted so they both were out the same amount so there wasn't any funny handling or odd tire wear. The spindles were perfect and gave me 0 problems. When you lower something with a spindle you get your drop by moving the wheel's mount point up. It doesn't affect your suspension at all, with the keys it re-indexes moving the suspension up in it's arc and decreasing suspension travel and causing some camber issues if the bars are cranked or bar is moved enough. Is your truck sitting level or was it sitting level when you took it to be aligned? Also how far out it it? Because I have had several vehicles lowered and my last one was a bagged dually. I can tell you that some negative camber isn't bad it will just slightly increase your tire wear. However saying that on my wife's truck we put about 50k miles on a set of Nitto 420s that was rarely rotated and for most of their life the alignment wasn't spot on. They were great when I sold the truck at the end of last year but the wheel bearing on the driver's side was worn and ultimately did the driver's side tire in. The passenger was fine and would have lasted another 15-20k miles I bet. So while it's not ideal a little bit isn't really that big of a deal. When I sold the truck I sold all the records otherwise I would get the paper work from each alignment and let you know exactly what mine was with each lowering kit.
I just looked at the picture good and I would set the truck with about a 1/2" difference between the front and the back and have the alignment checked again. It looks like there is atleast and inch or so of rake in your truck. Also make sure you have trimmed the front and rear bumpstops.
Thanks for all the help.
Also what does RAKE mean?
Rake means the front is lower than the back, or a tool used to gather leaves in the fall. I lowered one 3" in the back with coils and turned the torsion bars enough to level it. You have to trim the bumpstops because you're closing the gap between the bumpstop and suspension components. Plus you won't get all your drop if it's sitting on the stops. It will also hurt the downward compression on the suspension travel
What do you think??? And if you agree what spindles should i go for?
Thanks for all the help. Wish you were closer i would have stopped by first thing.
[QUOTE=Vinniety;4697760]I also noticed the drivers side rear is 1/2 inch lower then the right side rear. What the hell is going on???? QUOTE]
Thats called the Chevy "lean"...could be result of fuel tank on that side. I put an extra spacer on the spring that side to level it out.
