2001 SCSB 4.8 4x4 to AWD swap
Old May 19, 2021 | 09:18 AM
  #71
arthursc2's Avatar
Do not mix ratios. OBS has the 9.5 SF 6 lug as an option. 4wd ones are wider than 2wd, don't need an NBS or OBS SS rear end to get a beefy axle
Old May 19, 2021 | 09:59 AM
  #72
_zebra's Avatar
makes children cry
and it won't be so much your torque converter as it'll be the transfer case that'll crap a huge brick if you put two different diff ratios in the truck - because the front & rear driveshafts will be wanting to turn at different speeds
Old May 19, 2021 | 01:33 PM
  #73
kaze_v8's Avatar
Can you elaborate on what 9.5 SF is? Also how can i determine what gear ratio i have?
What are my options for getting the rear end to match? Would a gear swap be sufficient? Sorry for all the questions.
Old May 19, 2021 | 01:42 PM
  #74
arthursc2's Avatar
pop the cover, count the teeth and divide them lol
swap gears if you have to, its not a big deal. If youve never done it before, pay a shop
9.5 SF = 9.5" ring gear semi floating axle. The cover has 14 bolts on it, some refer to it as a "14b"
Its an AAM axle, not a GM 14 bolt, but its a stout piece of machinery and you can find them under GMT400 Z71s and W/Ts. Maybe other packages; but at least those 2; v8s of course
Old May 19, 2021 | 02:02 PM
  #75
kaze_v8's Avatar
Good deal, I guess ill be swapping out the gears in the rear then. Thats pretty cool to know the rear axle of a k1500 is wider than the C1500, any idea how much?
Ive got some beefy wheels I just got for the rear, and hope they poke haha
Old May 19, 2021 | 04:51 PM
  #76
arthursc2's Avatar
its 2 or 4", something pretty significant
Old Sep 26, 2022 | 06:23 PM
  #77
Wise421's Avatar
Registered User
Default Trans harness
Did you have to change the trans harness for the conversion?
Originally Posted by Midnight
So here is a thread for my 2001 Silverado SCSB stepside with a 4.8 and 4L60E and 4 wheel drive. Decided to pick up some parts and do the AWD swap on it. So parts include:
NVG-149 Transfer case with less than 10K on it
Front differential out of AWD equipped vehicle
AWD front drive shaft
So I had the parts looked over by a trans shop down the road and the guy said everything looks good so I will be doing the AWD swap now that the garage space is available. Ill try to take a few pictures of the swap.
Attachment 142658
Attachment 142659
Old Apr 8, 2024 | 08:11 PM
  #78
NorthernEdge's Avatar
no you don’t for this swap
Old Jun 7, 2024 | 07:24 PM
  #79
Toys-N-Joys's Avatar
Registered User
If my truck is originally a manual transfer case how do I lock the front differential into 4x4? Do I just put the truck in 4x4 when I remove the t case? I have a nvg149 and a front driveshaft. Was hoping to use my original front differential
Old Jun 10, 2024 | 02:32 PM
  #80
arthursc2's Avatar
You can swap the passenger side tube to an AWD one, you can swap the front diff with an AWD one or you can apply 12v to the CAD servo and leave that like that. You might be able to mechanically lock it in gear- but its been a long time since Ive been in a CAD GM axle and I don't recall any of the specifics
