Which 2" coil spring spacer? From $40-$120 -Quality?
Old Jul 11, 2012 | 05:21 PM
A Low Dime's Avatar
13 Second Truck Club
Default Which 2" coil spring spacer? From $40-$120 -Quality?
I want to toss a pair of 2"-2.5" coil spring spacers in my 01' to bring the front up closer to level with the rear. I dont want the aluminum ones, but Ive found many different brands of polyurethane spacers, ranging from around $40 to $120.
Is there a difference in quality or anything between the cheaper ones vs the more expensive? Sometimes its better to spend the extra on better products, but should I now?
There are also several brands sitting right at $120 for the same thing, differences?
Amazon.com: Prothane 4-1706-BL Black 2" Lift Front Coil Spring Lift Spacer Kit: Automotive Amazon.com: Prothane 4-1706-BL Black 2" Lift Front Coil Spring Lift Spacer Kit: Automotive
Amazon.com: Daystar KG09101BK Comfort Ride 2" Leveling Front Coil Spring Spacer Kit - 2 Piece: Automotive Amazon.com: Daystar KG09101BK Comfort Ride 2" Leveling Front Coil Spring Spacer Kit - 2 Piece: Automotive
Amazon.com: Pro Comp PLG09101 2" Front Coil Spacer for GM 1500 88-07: Automotive Amazon.com: Pro Comp PLG09101 2" Front Coil Spacer for GM 1500 88-07: Automotive
Amazon.com: Skyjacker C209P 2" Coil Spring Spacer: Automotive Amazon.com: Skyjacker C209P 2" Coil Spring Spacer: Automotive
Old Jul 11, 2012 | 05:26 PM
nonnieselman's Avatar
Lemme know how that goes. I wanted to run 285s but i dont think they will fit without scrubbing.
Old Jul 11, 2012 | 05:28 PM
A Low Dime's Avatar
Im running a 285/60 on my Titan 18s now. It rubs a little on full lock.
Old Jul 11, 2012 | 10:04 PM
midevil1's Avatar
I have a set of those in my garage that I never did anything with. If you need them I will sell'em.
Old Jul 11, 2012 | 10:26 PM
A Low Dime's Avatar
I sent you a PM for some more info.
Old Jul 11, 2012 | 10:29 PM
Thats a 31.5x11.2 roughly.
I wanted to try a 31.5-32"
Old Jul 11, 2012 | 10:31 PM
A Low Dime's Avatar
If I do the spacers in front and a lift block in the rear, Id like to try out a 285/65. A few more tire choices and availability for that size compared to the 285/60
Old Jul 11, 2012 | 10:42 PM
Yea. I wanted a 275 minumum. But hardly anybody makes them in a A/T.
285 has more choices but most are 33s.
Old Jul 11, 2012 | 10:51 PM
Cooper makes the A/T3 in a 275/70/17 and it comes out to be a 32.
Thinkin thats gonna be my next tire.
Old Jul 11, 2012 | 11:11 PM
A Low Dime's Avatar
Ive read good reviews on the Cooper Zeon LTZ. Id like to try those out.
Zeon LTZ - OnlineTires.com
Or maybe some Hankook Dynapros.
