2-4 drop done!!!
Old Mar 9, 2009 | 07:59 PM
1andOnly's Avatar
Default 2-4 drop done!!!
Well I finally finished my drop Im running 305/40/22 no rubbing or turning problems,well I took it to get an alingnment and my inner tie rods were no good had them replaced trucks rides like new...Im running spindles,shackles,and hangers....and Belltech street perfomance all the way around.. Thanks to Bill But I have one problem on the rear the drivers side is lower than the passenger side (about an inch) what can I do to fix it....Sorry no pics I need to clean it up but they will come after the rain passes...And again Thanks Trever1t.
Old Mar 9, 2009 | 08:01 PM
dlt76028's Avatar
my drivers side is higher about an inch
Old Mar 9, 2009 | 08:02 PM
D_reks{5.3}'s Avatar
it is very common to have to replace inner tie rods in these trucks..Ive had to change mine. Lets see some pics of the drop
1andOnly's Avatar
Whats up with that.
Old Mar 9, 2009 | 08:04 PM
1andOnly's Avatar
My truck is dirty azz hell I want to wash it so bad but dont want it to rain on it....
Old Mar 9, 2009 | 10:42 PM
2 tone 02's Avatar
You can pull the passenger side overload leaf to level it out, but you may run into problems with the axle bottoming out on the framem if you carry heavy loads or take bumps at fast speeds!
Old Mar 9, 2009 | 10:59 PM
dlt76028's Avatar
i think just pulling one overload would mess up the whole rear end. i wouldn't advise that.
Old Mar 10, 2009 | 12:16 AM
My truck is about an inch higher in the front and back and the passenger side. I've got a 2/3 drop...
Old Mar 10, 2009 | 03:08 AM
00Silv4.8's Avatar
I think my passenger side is maybe half an inch higher. Definitely had more travel with that shock mount. I think it's something you just gotta deal with. And if you pull the helpers do them both. Don't half *** ****. And you will have frame slapping problems with both of them out. Notches recommended and of course you'll have to take it easier anyway
Old Mar 10, 2009 | 09:59 AM
454navyss's Avatar
eibach makes a spacer to level it out, you put it on top of your front spring, i think its about $25-$30.
my truck now has ~3/5 drop and sits level, didnt sit level with 3/3 drop though
