1st gear
Old Mar 14, 2006 | 07:13 PM
z7199's Avatar
Default 1st gear
I drove my truck today for the first time after the swap and it seemed right!!!!
However I did a search and alot of guys have said 1st gear SUCKS. I am just wondering how sucky it seems like I have no power until about 3000K RPM in first. any opionons are great on what you think yours feels like
Old Mar 14, 2006 | 07:46 PM
seeyaa's Avatar
yeah it sound like you need a stall. im going with a 3000 of some kind. how did you work the crossmembers because i have got some stuff comming from speed E. but not the crossmembers and mount. But congrats on the in stall how long did it take you?
Old Mar 14, 2006 | 11:55 PM
1slow01Z71's Avatar
Tin Foil Hat Wearin' Fool
you have tall tires, stock motor and no stall its going to be SLOW
Old Mar 15, 2006 | 12:05 AM
James B.'s Avatar
There isn't enough gear range in the 4L80-E to give you the same scoot off the line your 4L60-E did. You've already got 4.10's, that's the most I'd put in a 10-bolt.
A torque converter will make up that difference.
(To get my first gear to be as violent as I wanted it I am running a 4.56:1 rear end with 30" tires and a 10.5" torque converter with a 3500RPM stall speed. On a slight incline it will spin those 30" 285's hard enough to shift to second, grabs traction, then downshifts back to first.)
You could always add more power....
Old Mar 15, 2006 | 07:03 AM
z7199's Avatar
If I was to get a stall I will not be able to tow right? That is what is I heard I need to tow so should I just deal with it till time for the 6.0? Also what is some more "power adders" I could do that is kinda cheap
Old Mar 15, 2006 | 07:42 AM
ap2002's Avatar
i heard if you get a TB stall (2500-2600)youll be able to keep all of your towing capabilities???
Old Mar 15, 2006 | 08:50 AM
James B.'s Avatar
Trailblazer Torque Converters (translated from "TB stall") are for 4L60-E's.
There are several companies making 4L80-E converters with stall speeds around 2600 RPM. Yank is one of them. Keep it around 2400-2600 and you'll retain your full towing capacity.
Old Mar 15, 2006 | 10:22 AM
Wilde Racing's Avatar
How do I change this text
Just got to do some reasearch before you buy.
Old Mar 15, 2006 | 05:53 PM
z7199's Avatar
The only other problem with getting a stall is I would have to pull that HEAVY *** TRANNY AGAIN I may look in to it
Old Mar 15, 2006 | 06:02 PM
1slow01Z71's Avatar
Welcome to the multiple tranny swap club thread
ferrellrooster
Mar 6, 2025 03:22 PM
pittman
Jan 19, 2016 07:06 AM
EmmerichLSx
Sep 14, 2015 09:47 AM
flatblack83
Sep 7, 2015 07:52 PM
MileHighSierra
Jul 12, 2015 12:23 AM
