1994 rearend in a 99+ silverado?
Old May 26, 2010 | 01:09 PM
dlt76028's Avatar
Default 1994 rearend in a 99+ silverado?
Will a 94 rearend from a chevy truck fit in a 99+ chevy truck? And if it was drum brakes, can you swap disk onto it?
Old May 26, 2010 | 01:21 PM
RandomHero's Avatar
I want to say the spring perches are a different width apart and that the yolk is different. I'm 99% sure it won't bolt in without some modification, but I don't believe you have to do a ton to get it in there.
Old May 26, 2010 | 03:18 PM
dlt76028's Avatar
hmm well it wouldn't be worth it unless it was a direct bolt in. thanks
Old May 27, 2010 | 12:04 AM
bohr898's Avatar
Restricted User
unless you want to spend money on a down grade then dont do it.... the carrier bearings are smaller on the inside... the spring perches are about 1.5 inches wider on your truck also...
Old May 27, 2010 | 07:44 AM
dlt76028's Avatar
good to know. thanks
Old May 27, 2010 | 06:54 PM
05RST2NV's Avatar
I put a 12 bolt from a 94 4x4 under my 2000 single cab. We shortened it 1in on each end, put mosier axles and a eaton unit in it. The spring perches do have to be rewelded. The drum brakes were easy to hook up and we then could easily fit a 15" rim on back and tuk some meat under the rear fender wells without minitubbing it.
85SS/85GN
Aug 7, 2015 04:30 PM
sprayedenali
17
Aug 7, 2015 08:15 AM
Offroadunleashed
Jul 20, 2015 02:25 PM
davis28905
Jul 8, 2015 03:20 AM
