10 bolt to 66 12 bolt swap
Old Apr 8, 2018 | 06:55 AM
LOWnEASY's Avatar
Default 10 bolt to 66 12 bolt swap
I got a 12 bolt from a 66 pickup for pretty much free so I'm going to see if i can make this work
I need a drag setup so need wheels any way, 5 lug 12 bolt axles are cheap, and 12 bolts are stronger so why not?
The nbs 10 bolt measures 68.5 wms>wms
The 12 bolt truck measures 62 wms>wms
68.5-62=6.5. 6.5/2=3.25. So the rear is 3.25 narrower each side than the 10 bolt
Most nbs drag setups I see run 6.5bs so my new wheel bs would be 3.25, most popular wheel back spacing comes in increments of .5. So hopfully i can make a 3.5 bs work.
Any one see any thing wrong with my math? Or any unforseen problems I might encounter?
Old Apr 8, 2018 | 03:38 PM
axisT6's Avatar
The axle in your truck is stronger than that 12 bolt.
Old Apr 9, 2018 | 03:16 PM
ACAMS's Avatar
Also the 10 bolt pinion is bigger ..... Put an aftermarket carrier in the 10 bolt and be ahead!
Old Apr 9, 2018 | 09:19 PM
LOWnEASY's Avatar
Is it because it's the truck 12 bolt? Cause I've always been under the impression that 12 bolts were stronger than 10 bolts..
Old Apr 10, 2018 | 08:22 AM
ACAMS's Avatar
Right! .... a car 12 bolt has a bigger pinion and is stronger.
The 12 bolt has an 8.875 diameter ring gear vs the 10 bolt 8.6, but other than that it is no better and the truck 12 bolt has the small pinion.
Three6GMC
Jun 22, 2014 08:54 PM
Schnell_MS
Sep 18, 2013 04:37 PM
(Ken)-96GMC K1500 SC
May 3, 2003 02:24 PM
