1 shim, 2 shim, 3 shim or no shim?
Old Mar 27, 2012 | 10:28 PM
06sierra5.3's Avatar
Default 1 shim, 2 shim, 3 shim or no shim?
First tranny I built I used 2 servo shims. No upgraded internals, line pressure was turned up and the output shaft grenaded.
I recently bought some parts from Pro Built and other places. Pro built recommends NO shims. However I am inclined to go with 1 or 2 shims, but leave the line pressure stock.
Dana at Pro Built seems like he knows his stuff, but Im afraid the shifts wont be firm enough. I just dont want to have to tear it apart again if its not the way I like it. I do enjoy the very crisp shifts, but not neck snapping.
thoughts?
Old Mar 27, 2012 | 10:31 PM
07NNBSVMAX's Avatar
From what I've read on here if you do the boost valve with no stall converter then no shims if you do the boost valve and have a stall then 1 shim. Idk about no boost valve..
Old Mar 27, 2012 | 11:08 PM
Im using a boost valve and have 3k stall
Old Mar 28, 2012 | 03:24 AM
07NNBSVMAX's Avatar
I'd try 1 shim. I've read you're not supposed to boost pressure in the tune if you're using the boost valve for fear of broken hard parts.
Old Mar 28, 2012 | 12:44 PM
Vince B's Avatar
With the late housing I always use one shim with the gold spring seat.
Old Mar 28, 2012 | 08:53 PM
You talking servo shims or accumulator shims? Sounds like you're talking about the 2nd gear accumulator.
Old Mar 28, 2012 | 09:31 PM
I can verify that. My output shaft grenaded and took out EVERYTHING. both planetaries welded together, the case wasnt even salvagable.
MyLs1Hauls- Servo shims. the Transgo shift kit comes with 3 shims for the servo and gives you a guide in the instructions.
I think I'll stick with one this time and stock line pressure. should take it down a few notches.
Old Mar 29, 2012 | 01:11 PM
The Intermediate/overdrive servo shims are gold, several inches in diameter, and only 2 are included. The accumulator shims are silver, and there are 3 of them. They look like thick flat washers.
Old Mar 29, 2012 | 06:46 PM
Vince B's Avatar
Fail! JFWY!
Old Mar 30, 2012 | 11:23 AM
You're right, it is the 3 silver ones. I am losing my mind with all these parts. Im trying to learn how all this stuff works and what exactly they are. Its overwhelming
