05 LS2 GTO converter work in a truck?
Old Jun 9, 2011 | 07:46 PM
flippindabird's Avatar
Default 05 LS2 GTO converter work in a truck?
i found a guy selling an '05 GTO LS2 cam, springs, torque converter and valves for $150... i was thinking i can use the valves and springs in my heads, and use the cam and converter, all i need is a timing chain and gaskets and id have a converter/cam swap for a few hundred. then i just get my heads ported, milled slightly, cut for the bigger valves and assembled and id have a decent combo for very cheap, but if the converter wont work, ill try to get the rest cheaper lol and use a 4.2L trailblazer converter... btw approx how high will the tb converter stall behind an lm7? and i think this is the wrong category to ask this in but to group all questions together, how much should i mill the heads and what gasket do i use to get around 10.5:1 compression? and would i be around 350+ chp with these mods and a good tune with all the other boltons(headers &exhaust, ud pulley, efans etc)?
Old Jun 9, 2011 | 07:49 PM
also anyone know of a good machine shop for LS head porting in the NEPA, NNJ or Hudson Valley NY areas?
Old Jun 9, 2011 | 07:55 PM
is there a cheaper place to find all this stuff in this kit (head bolts and gaskets req for cam and head http://www.summitracing.com/parts/SLE-12506/swap) thats an outrageous amount of money for gaskets and bolts imo
edit***** found this http://www.summitracing.com/parts/SLE-12506/ but i doubt the head gaskets will work, the price is a HELL of alot better then that slp nonsense though, but doesnt include timing cover gaskets... 86$ for a comp timing set sounds ok???
Old Jun 9, 2011 | 09:12 PM
Vince B's Avatar
I can't help you with the motor stuff but yes the converter will work in your truck.
Old Jun 9, 2011 | 09:22 PM
ok will it be an upgrade(higher stall)?, and i dont know if i mentioned it but my truck is a 4wd does that matter?
Old Jun 9, 2011 | 09:29 PM
Vince B's Avatar
I really doubt that it will be much different than what you have now. Maybe 200rpm higher if your lucky if not excatly the same.
Old Jun 9, 2011 | 09:45 PM
yeah thats what i was thinking vince, maybe ill save the time and energy and leave the stocker in then get a tb converter when i get a chance, i dont wanna go through the trouble for 2-500 rpm when its really a driver not a racer if i can stall 1000 to 1500rpm higher thatd be great... im just gonna ask this guy if i can get everythingelse a little cheaper w/o the converter
lxcoupe
Aug 15, 2015 06:13 PM
jmarkway
Jul 18, 2015 09:23 PM
black6spdz
Jul 16, 2015 01:32 AM
Mzay
Jul 6, 2015 11:05 PM
caviness
Jul 5, 2015 10:49 PM
