Many times a pinhole leak in the transfer case is due to broken or worn guides or a chain with excessive slack. Can you give us an idea where the leak is specifically on the case?
g |
4 Attachment(s)
Gilbert, thanks for the follow-up.
The leak was from the classic pump rub issue. The rattle clip was not even broken, but the 3 of the pump ears had worn into the case. One was enough to puncture all the way through. I cleaned, sanded, applied JB Weld to the hole and then installed the Merchant Auto CNC Pump Rub fix. Total cost in parts/materials about $120 including new fluid. Not great pics, but you can see below. Attachment 148520 Attachment 148521 Attachment 148522 Attachment 148523 |
