what flex fuel sensor
Old Apr 13, 2023 | 02:45 PM
TorqueBT's Avatar
Default what flex fuel sensor
what flex fuel sensor are you guys using on you gen 3 trucks with the P59 pcm?
Old Apr 13, 2023 | 04:32 PM
smokinlmm's Avatar
I’m using a Dsx kit.
Old Apr 13, 2023 | 05:16 PM
TorqueBT's Avatar
i forgot to add that I have a return style fuel system with an lines. What is your make, model and year?
Old Apr 13, 2023 | 06:46 PM
FFDP's Avatar
The sensor itself I use a Continental sensor that GM sells.
Amazon Amazon
Old Apr 13, 2023 | 07:49 PM
smokinlmm's Avatar
I have a return system with an lines and a regulator. I put my flex sensor on my return line under the hood right after the regulator.
Old Apr 14, 2023 | 11:48 AM
The_W's Avatar
I have not installed but bought the one below. Its just like FFDP but comes with connector and compression fittings. I had to buy two other fittings AT165106ERL (earls fitttings from summit) for the stock fuel line to screw into each other. I will probably put mine under the cab somewhere since a LSA will be going on mine and space is limited.
https://www.highflowfuel.com/genuine...iABEgKhIPD_BwE
Old Apr 14, 2023 | 12:12 PM
shakenfake's Avatar
Shlumpt
5 Year Member
@The_W Just put it next to the stock filter.
Old Apr 14, 2023 | 01:18 PM
The_W's Avatar
I agree, thats where I saw some guy on youtube do it. Only plus I see on doing it under hood is your wiring is easier and shorter.
Old Apr 14, 2023 | 05:20 PM
Rockrz's Avatar
Is this an older truck back when they had fuel filters?
Every GM vehicle I've owned 2009 or newer didn't have fuel filters.
Old Apr 14, 2023 | 06:32 PM
shakenfake's Avatar
Shlumpt
5 Year Member
Correct, after 02 they moved it to inside the pump.
