walbro issue
Old Jun 11, 2013 | 07:06 PM
hsiriyob's Avatar
Default walbro issue
I installed a 255 walbro ss340 last weekend into my 2004 silverado. Install went well and it fired right up and ran great. I went on a cruise today and the truck started acting like it was running out of fuel. I put ten gallons in and it is doing the same thing. Ill check fuel pressure off my rail tomorrow when i get the tool, but does anyone know of this issue with this pump? I have also heard that it could be a relay? the pump primes so its getting power. Figures after all that work a cheap pump would fail
Old Jun 11, 2013 | 07:47 PM
Chevy_King1500's Avatar
did you replace the hose from the pump to the top of the tank? check fuel pressure and report back
Old Jun 11, 2013 | 09:58 PM
hsiriyob's Avatar
yes. Im pretty sure its the way i mounted the pump. I believe it jumped up higher than the fuel level and over heated. ill check pressure tomorrow.
Old Jun 13, 2013 | 05:30 PM
hsiriyob's Avatar
checked fuel pressure today and im not even getting 1 psi. decompressed the valve and no fuel at all. assuming its the pump im going aeromotive 340.
Old Jun 13, 2013 | 05:38 PM
what kind of hose did you use to replace the old one? if its not "submersible fuel line" it may have swollen shut..
Last edited by Chevy_King1500; Jun 13, 2013 at 07:35 PM. Reason: stupid keyboard sucks at spelling
Old Jun 13, 2013 | 06:13 PM
2toneblown's Avatar
I would bet its the hose in the tank as well
Old Jun 13, 2013 | 07:18 PM
hsiriyob's Avatar
why kind of hose did you use to replace the old one? if its not "submersible fuel line" it may have swollen shut..
I believe it was 5/16th gates hose. If its not Can it swell close after 2 days? Ill check it this weekend after i get the bed off. here are some pics of the hose i used. Is this fuel submersible?
Old Jun 13, 2013 | 07:30 PM
hsiriyob's Avatar
dropped some of the hose in some gas ill look at it in the morning and report back.
Old Jun 13, 2013 | 07:33 PM
i doubt thats the right hose, the hose comes in a plastic bag pre-cut.. i had the same thing happen to me, it sucks, i know.
i would just re-use the factory plastic one, take your time and get it right, the second time i had to pull the bed i got pissed and got in a rush.
needless to say i had to pull the bed a third time because a wire was holding the float down and causing a "low fuel" light..
just speaking from my experience/mistakes
Old Jun 13, 2013 | 08:03 PM
hsiriyob's Avatar
I asked for gates hose at autozone and asked if it was fuel submersible. Last time I trust an "expert". Glad to know I'm not the only one messing up. Ill look at napa for the right hose.
