walbro 450 install nnbs with pics
Old Dec 25, 2015 | 07:38 PM
Jake75's Avatar
Default walbro 450 install nnbs with pics
Not sure if yall seen my other post about me having issues with my fuel pump well i took the bed off and pulled the fuel pump. What is yalls take on the install? It was done by a shop in Houston maybe a yr ago. Would yall have done anything different?
Old Dec 25, 2015 | 09:39 PM
03sierraslt's Avatar
So this is a returnless fuel system right? Do you have a fuel pressure gauge? What's idle pressure?
Old Dec 25, 2015 | 10:04 PM
Jake75's Avatar
Its converted to return style via fuel regulator. Idle pressure is about 65-70
Old Dec 26, 2015 | 08:49 AM
Isn't the regulator in the tank? That idle pressure is way high. What issues were you having.
And let me guess, as soon as you give it throttle the pressure drops to 58-60
Old Dec 26, 2015 | 10:34 AM
Jake75's Avatar
i have an aftermarket external regulator. No the pump has been fine since i had it installed but up until about a week ago somethimes it doesnt wanna build pressure to start, after i cycle the key a few times it starts right up
Old Dec 26, 2015 | 11:16 AM
George C....'s Avatar
Formerly ScreamingL
Typical of a walboro carry on
Old Dec 26, 2015 | 11:22 AM
What is your preferred pump for a similar application?
Old Dec 26, 2015 | 11:23 AM
Is the pump turning on when this happens?
Old Dec 26, 2015 | 11:40 AM
Formerly ScreamingL
Walboros work they just bleed off pressure over time
Ive gotten so used to cycle key its like 2nd nature
Old Dec 26, 2015 | 11:53 AM
I heard some people complain about it but have never seen it on any of my own or others I've done.
