walboro 255 part # 99-02 intake?
Old May 15, 2013 | 11:19 PM
2000chevysilverado's Avatar
Default walboro 255 part # 99-02 intake?
As im building my turbo kit and needing to upgrade my fuel system looking for part # for intake walboro 255. I also will be needing another fuel bucket for 99-02
Old May 16, 2013 | 09:27 AM
brandon6.0's Avatar
here ya go:
Racetronix - Fuel Pump Kit, GM Applications - Kit Configuration Page
In the drop down menu choose the walbro 255lph.
Old May 16, 2013 | 10:31 AM
Last Call's Avatar
TOTM: January 2007
The bucket is too small to allow a 255 to be dropped in without modification. You can either do a 255 inline or buy the whole drop in module. That is what I did and it has been working great.
Racetronix - FPM-007 - Fuel Module, GM SUV, High Perf. Type 007
Old May 16, 2013 | 11:03 AM
smokeshow's Avatar
Mod with training wheels
Intake walbro?
Old May 16, 2013 | 11:25 AM
Ferocity02's Avatar
Originally Posted by smokeshow
Intake walbro?
Intank
In tank
In fuel tank
Confused me too for a sec
Old May 16, 2013 | 11:26 AM
Ferocity02's Avatar
What kind of power are you looking to make? You might quickly find that a 255 is too small.
Old May 16, 2013 | 09:47 PM
Originally Posted by Ferocity02
Intank
In tank
In fuel tank
Autotext pain sometimes
I dont think I will get over 400 at the wheels just soemthing more fun to go with the tr220 I picked up. This will be a rear mount turbo setup with 36lb injectors as well
Now with inline pump where has everybody been putting them seems simple. Do I need to do anything with stock pump or leave it in place.
Old May 16, 2013 | 09:58 PM
brandon6.0's Avatar
Just install the one I posted earlier. Run it in my stock bucket. Worked fine. I even cut the bottom out to let the filter set on bottom of fuel tank. Been workin great so far.
Old May 16, 2013 | 10:09 PM
GMCtrk's Avatar
I installed a Walbro 450 in my stock 2000 fuel module assembly last week. It's a direct replacement for stock aside from roughly 5-10 minutes with a dremel to open up the hole at the bottom for the sock attachment and getting rid of the ridges at the base so the pump can sit flush with the base.
Old May 16, 2013 | 10:23 PM
Thats what I thought I knew I seen someone do this before. I dont think I would need a 450 for what im planning but I will keep it in mind what was the part number. So what would be the right pump out of all this that would work inside the tank?
