Under bed fuel cell guys....have a question
Old Aug 31, 2012 | 07:15 PM
BlackGMC's Avatar
Resident Retard
Originally Posted by fastnblu
Corey, looks great!!!
What is removed from tune as it relates to emissions?
So my guess is the green evap from engine bay is either missin or hole filled? If so, & they do some kinda visual emission testing where u are, do they pop the hood? I'd hope not, at least for your sake. I'm also thinkin u removed all related lines, so therefore the big canister that used to be above driveshaft?
Who did the work?
Thanks i did all the work
The tune, Basically you just turn off all the tests with EVAP in them.
Yes i removed all the fuel lines, evap lines, charcoal canister, etc.
Old Aug 31, 2012 | 07:34 PM
fastnblu's Avatar
U know, I was alookin at your sig, & noticed somethin...a 6L. Maybe it was while I wasn't on PT from like Dec. '11 / or Jan. '12 til June '12.
U had a 4.8, so when did u go to more cubes?
And the 12.78 was runnin the 6.0, correct?
Any more fuel cell pics, like diff. angles or ...?
Old Aug 31, 2012 | 07:47 PM
blown02408's Avatar
02 w/ lowest mileage 2800
If the EVAP tests don't run, how do you pass emissions? Right now I have all the EVAP lines tied back into my fuel cell vent and the stock sending unit is modified to fit also, but I would love it if I could do away with all that crap!
BlackGMC's Avatar
Resident Retard
Yeah i switched to a 6.0 about 1.5 years ago, and yep the times were with the 6.0 with the 60e combo...
here is my build thread
https://www.performancetrucks.net/fo...st-etc-504745/
Here are more pics i did not post.
Fuel System pictures by BlackGMC - Photobucket
Old Aug 31, 2012 | 07:48 PM
BlackGMC's Avatar
Resident Retard
When you turn off the tests the tests go to "ready", same thing you do when you remove the rear O2 sensors...
Old Aug 31, 2012 | 11:10 PM
xddesign26's Avatar
^That's some good info right there! That makes things alot easier then. Love your setup BlackGMC....been following your build thread for awhile.
Old Oct 9, 2012 | 06:46 PM
xx_ED_xx's Avatar
I found a plastic cell for like a 48 chevy 18 gallon for mine. I will get pics when i get back from deployment. The dimensions where the closest to what i was looking for. I also removed all the emissions crap.
Unfortunately on my setup the air bags are behind the rear diff. so made space smaller
Old Oct 9, 2012 | 06:59 PM
phasemaster1's Avatar
Originally Posted by BlackGMC
Well i removed all of that emissions crap and adjusted the tune and mine will pass the computer test. Only problem if i come across an emissions guy that is actual smart and does a visual inspection i am screwed. Below is my cell that uses the factory filler neck location
Hey Corey is that your vent tube with the loops on the right. If it is how has that been working can you smell fuel at all?
Old Oct 9, 2012 | 07:45 PM
BlackGMC's Avatar
Resident Retard
Yep that is the vent tube with the coils. I have actually updated it to work better. That design allowed fuel to get down to the coil. I moved the coil right next to the cell and made sure the coil was higher than the cell. Then i ran a line down to the tail light with another larger coil, roughly 11 inches tall. I really dont have any gas smell.
When i redo it i am going to use this
https://www.pegasusautoracing.com/pr...asp?RecID=8453
Old Oct 9, 2012 | 08:00 PM
1989k1500's Avatar
135 bucks, holy cow!
