Stock like behavior from OEM fuel tank with fuel pump upgrades
Old 03-17-2017, 07:04 PM
03sierraslt's Avatar
I'll have to dig them up.
Old 03-17-2017, 09:17 PM
TrendSetter's Avatar
i wanted the same thing mentioned in post 1. i ended up building a surge tank that fills from the regulator return line with a big pump in the surge tank. the tank is all stock, it all works really well. the big pump comes on under boost.
Old 03-18-2017, 07:30 AM
In this pic you can see where the return line attaches.
This is the Venturi hole opened up for the higher flow rate of a 450 pump.
This is how you remove the Venturi from bottom of bucket to drill it out a bit. It's fine with a 255 pump but a 450 requires opening it up.
