Stock injectors replace with Deka 80lb injectors?
Old 04-09-2017, 01:26 PM
Intimidator_ SS's Avatar
Default Stock injectors replace with Deka 80lb injectors?
I got my 80lb injectors #110324 for my 06 Silverado but the connections are different. Is there a way I can make them work for my truck?
Old 04-09-2017, 01:33 PM
03sierraslt's Avatar
Either re wire and install new plugs or get injector adapters.
Ps. Why do you keep posting these threads in the classified section?
Old 04-09-2017, 01:53 PM
I actually got the 80lb injectors from a 03 and going to swap them put my stock injectors on the 03 and the 80lb on my 06. Just can see how they changed the plugs on the 03 looks like they change the harness to make them work. Is this the way to do it?
I was making my searching around and was reading a post in the classified section I was thinking it was the right section to post my question
Old 04-09-2017, 02:19 PM
Just found out they adapted the wires tanks for your help. This is my weekend project and trying to do all I can to finish.
