Stay on pump 93 only, or add meth? 11 psi
Old Oct 25, 2013 | 10:46 AM
  #21
Chevy_King1500's Avatar
Originally Posted by Choda
thanks! I believe the stock gap is 36 right?
Whats your Timing at wot?
16 degrees, seeing about 160 kpa on the scanner
so what happens after we max out the air flow in the timing table @ 1.2 g/cyl
Old Oct 25, 2013 | 01:50 PM
  #22
69Camaro427's Avatar
No, it would build more cyl pressure.
Ahhh okay that makes sense with a higher over lap. Thanks
Old Oct 26, 2013 | 06:04 AM
  #23
went to the gas station to check on e85 and it was only $2.55
I might go that route just to try something different. my next project/track car will be e85 for sure
I will start off by just upgrading the fuel pump and go from there. I will likely need more injector but I will worry about that later
GXPJAY
Feb 13, 2022 08:15 AM
05GMC4.8
Aug 7, 2015 09:55 PM
MS3Z
Jul 30, 2015 06:17 PM
Gadgetized
Jul 18, 2015 02:15 PM
Mossyoakglock
Jul 17, 2015 08:30 AM
