Stay on pump 93 only, or add meth? 11 psi
Old Oct 24, 2013 | 11:55 AM
kelsey_canard's Avatar
Yea e85 is going to happen for me as much as I'd like it to. The nearest station is 80+ miles from here. I've even talked to some local stations about possibly picking it up. No bueno.
I'm also all for methanol, but really considering if I even need it at my boost level. I figure if I turn it up anymore with the meth, that I will just push head gaskets.
Maybe I just need to sack up, and order a meth kit, studs, and gaskets. Then just crank it up until my little turbo taps out.
Old Oct 24, 2013 | 01:15 PM
slowec's Avatar
I did not push water with meth until 20 psi. rode 14 psi for a good while no problem. I would throw an Alky-control kit on it with a M15 nozzle , tune it for 11.5 to 1 air/fuel , 14 degrees timing, and 14 psi and enjoy daily!
Old Oct 24, 2013 | 01:50 PM
Choda's Avatar
How much meth did u go through? Did u have it spray at wot? Or a rpm window? Or a set psi?
I'm still worried running out of it
Old Oct 24, 2013 | 02:09 PM
X2. Is 15 gph too much to run off of a Hobbs?
Old Oct 24, 2013 | 11:51 PM
Mangled03gmc's Avatar
Baltimore Whore
I am on 12lbs on 93, some times 89-91, never a issue, plugs look fine. 11 psi is not enough for the need of meth unless your really trying to get every bit out of it in the timing/tune
Old Oct 25, 2013 | 12:50 AM
69Camaro427's Avatar
Not related to the meth topic, but would a different cam profile with higher lsa help in crease advance? say 115-117Lsa range?
Old Oct 25, 2013 | 06:23 AM
Choda's Avatar
What plus and gap Re you guys using? Also what motors?
I'm on a 2009 stock 5.3 w tr6 at 32 gap. I am going to try a br7 at 28 to see what happens
Old Oct 25, 2013 | 07:09 AM
Chevy_King1500's Avatar
2002 lm7 tr6 stock gap
Old Oct 25, 2013 | 07:54 AM
Choda's Avatar
thanks! I believe the stock gap is 36 right?
Whats your Timing at wot?
Old Oct 25, 2013 | 08:35 AM
03sierraslt's Avatar
No, it would build more cyl pressure.
