S10 Fuel system cant hang, Changes will be taken
Old Nov 25, 2014 | 12:58 PM
roastin300's Avatar
Registered User
Default S10 Fuel system cant hang, Changes will be taken
My mods are in my signature. I am currently installing the heads and cam so right now these issues are occuring on stock LS1 heads and cam.
Here is the current fuel system:
Walbro 255lph in tank
Stock S10 fuel lines
Stock LS1 injectors/rails
What happens:
FP and resultant AFR are fine N/A, but when I activate the nitrous it goes lean for a bit and then slowly catches up. Not sure if its the pump or the lines causing the issue.
Anyone know what the stock S10 fuel lines can support? If I toss a Walbro 400lph pump in there could this resolve the issues or should I step up to a larger feed and return? I would like to keep the stock rails (97-98 vette return style) so I will need to adapt from the standard size inlet outlet ports on the rail to the larger feed and return. I will be installing 42lb/hr injectors when the heads and cam go on. Thanks!!
Old Nov 26, 2014 | 01:19 PM
banker099's Avatar
how long is the lean spike?
Old Nov 26, 2014 | 03:13 PM
TXsilverado's Avatar
have you verified with a pressure gauge?
RONIN LSX
Aug 10, 2015 04:45 PM
TAPyvehc93
Aug 8, 2015 06:35 PM
MS3Z
Jul 30, 2015 06:17 PM
4B11T
Jul 13, 2015 03:48 PM
