Returnless fuel sytem on return style fuel system
Old May 17, 2021 | 09:47 PM
Bam444's Avatar
Registered User
Question Returnless fuel sytem on return style fuel system
i have a 99 gmc sierra 2500 2wd 6.0L lq4 (NBS) looking at getting a jegs version of a FItech 70076 intake with a 92mm throttle body. i have 2007+ tahoe decapped injectors and other mods like cam and dual valve springs and 241 ls1 heads.
how would i retrofit that to my fuel system since i have a return style fuel sytem. will upgrade pump to the holley 510-12-952 on jegs.
this intake needs a returnless fuel system and im not trying to redo the whole system if it can be avoided and will be willing to cut out any evap as need.
fuel pump: https://www.jegs.com/i/Holley/510/12-952/10002/-1
intake: https://www.jegs.com/i/JEGS/555/513050K/10002/-1
Old May 17, 2021 | 10:24 PM
FFDP's Avatar
Decapped injectors are straight garbage, don't even run those. If you do, good luck trying to tune them. Find some stock 33lb/hr flex fuel injectors or anything larger than the stock 25lb/hr injectors that come in a 6.0.
That fuel rail on that intake looks like you can remove the cap on the passenger side fuel rail. All you'd need is another fitting, then a fuel pressure regulator and hose that connects back to the stock return line.
Old May 17, 2021 | 10:45 PM
Atomic's Avatar
I have a gauge for that
I wouldnt call that Jegs intake an upgrade over what you have unless you only care about 6500rpm+ performance.
Old Apr 30, 2023 | 05:20 AM
Blown06's Avatar
8 Second Truck Club
return fuel system better in everyway possible over a returnless. Just my 0.02
Go5.3tt06
Jun 19, 2014 11:41 AM
99bluefirebird
Oct 2, 2011 02:14 PM
sharpshooter
Aug 15, 2007 12:02 AM
Blown06
Sep 14, 2006 09:44 AM
Mangled03gmc
13
Aug 7, 2006 06:32 PM
