returnless fuel system
#21
The stock feed would be a little small for both pumps but it would work, its 6an. Unless your going to upgrade the rails aswell I would just leave it all stock other then the pumps and wiring. You can hit 700rwhp with it like that no problem.
#22
i was going to run a new feed hose and just use the stock feed hose as return, im just trying to verify if the stock feed line has any type of 1 way valve in it or anything
going to be using stock rails and for sure would be under 700whp, so maybe i will just run my pumps all in stock and run my own return line off my regulator
thanks for all the help
#23
I'm doing the same thing just want to to 8an both ways ... do u have a parts list on doing this setup ? Really need it so I can get it all coming since turbo will be here in a few weeks
