returnless fuel system
Old Mar 25, 2013 | 01:29 PM
03regcab sierra's Avatar
Originally Posted by Jake99
I have a 02 pump bucket I can put the 255 in, then just get a return rail and run a 4an line back to the bucket, but ill look into it a little more and see what all is really needed
Just remember that bucket won't work in an 04 tank they have a bigger opening for the bucket. If u need one I have 2 spare tanks I can send with someone this weekend to kansas
Old Mar 25, 2013 | 01:48 PM
slowswb's Avatar
Originally Posted by 03regcab sierra
That would work as well but those filters are kinda pricey. Be cheaper to just swap the fuel rails over to return style since most guys have a set or 2 laying around
Good call but the old rails doent fit on the nnbs/tbss intakes.
Old Mar 25, 2013 | 02:00 PM
Jake99's Avatar
O ok, yeah iv never messed with one before so I didn't know, is there no way to bypass the reg and just tap in a new return line? If not a may pick you up on that tank offer
Old Mar 25, 2013 | 06:49 PM
blue0453's Avatar
I converted my 04 to return about a month ago. Walbro 400 with -8 feed. 10 micron inline filter. 13129 aero reg. Russel quick connect fittings to tie into factory fuel line/rail hookup. Factory feed as return dumping right back into the bucket..
Old Mar 25, 2013 | 10:54 PM
Yea u can just yank out the regulator in tank and tap the rail for a regulator up front. It would be the easiest route to make it return style.
I hope y'all get it figures out soon I'm dying to see what the truck will run on 150 shot
Old Oct 30, 2013 | 02:05 PM
timmay208's Avatar
kind of a older post but would -6an be enough for a feed line or return?
Old Oct 30, 2013 | 02:36 PM
Jake99's Avatar
Yes 6an would be fine with twin 225 pumps, that's what I ran on mine, however the factory return would only flow enough to go down to 65psi. I believe it gos down to 4an.
Old Oct 30, 2013 | 02:58 PM
timmay208's Avatar
i was thinking about running a new line for my feed, and using the factory feed line for a return
Old Oct 30, 2013 | 03:48 PM
Jake99's Avatar
All depends on how much pump you have, if you have twin pumps you can put one on a hobbs switch and you would be fine, and up to a 450 single pump you should be fine.
Old Oct 30, 2013 | 04:39 PM
timmay208's Avatar
yea i have 2 walbro 255 pumps, was thinking of just running the single for now untill i need the 2nd pump then do something to have it turn on only under boost or something to that effect
do you think it would be better to use the factory line for feed or return? Im debating on putting a sump on my tank and running my fuel pumps that way with a inline fuel filter vs intank like stock. Also ive read that the factory feed line is a 1 way with a check valve or something but cant seem to confirm if this is true or not
