retune/style with stock sensor
Old Jun 12, 2016 | 09:58 AM
MattOKC's Avatar
Default retune/style with stock sensor
Can someone tell me if this will work. I'll put an adapter on stock feed line coming out of fuel hat so the stock fuel pressure sensor will still increase/decrease voltage to pump. I'll run 8-an from there to filter then rails and from the regulator run 6-an to a bulkhead fitting on the fuel hat for return. I have a Walbro 450 in the bucket now with stock lines, stock rails, and decka 60s. I'll be adding Holley rails and Aeromotive reg
Old Jun 12, 2016 | 10:02 AM
MattOKC's Avatar
It's in a 2013 5.3 Silverado
Old Jun 12, 2016 | 10:48 PM
MattOKC's Avatar
Atomic? George?
Old Jun 13, 2016 | 12:25 AM
Atomic's Avatar
I have a gauge for that
I haven't messed with the newer trucks but where is the pressure sensor located? Do you still have the bypass valve in the tank?
Old Jun 13, 2016 | 08:35 AM
MattOKC's Avatar
[QUOTE=Atomic;5365463]I haven't messed with the newer trucks but where is the pressure sensor located? Do you still have the bypass valve in the tank?[/QUOTE
I think the sensor is in the top of the fuel hat. I don't have the bed off the truck yet. I removed the regulator when I put the Walbro in last year.
Old Jun 13, 2016 | 08:46 AM
Atomic's Avatar
So currently you dont have a regulator on there? I said you plan to add one, not already have one.
The way I understand the new system is the pump voltage is based on vacuum pressure in the intake manifold, basically running the pump slower when the flow isnt needed (idle/cruise), and increasing the voltage when demand is high.
So if you gut the filter and regulator in the tank and still use the FPCM in its stock calibration it should work fine with an aftermarket rail and regulator up by the engine. I think most guys just max out the FPCM table to make sure the pump is never under powered.
Old Jun 13, 2016 | 01:50 PM
MattOKC's Avatar
That's what I was looking for, thank you for the help
D1SCSS
Aug 29, 2016 11:21 PM
PSM
Jun 20, 2016 10:53 AM
TVS/HC
May 3, 2016 10:41 PM
AlwaysOnKill
Apr 21, 2016 07:05 PM
JASON 77
Apr 17, 2016 01:19 PM
