question about fuel pressure and IDC
Old Jan 11, 2013 | 10:46 AM
smokeshow's Avatar
Mod with training wheels
I think it might be a good idea.
Old Jan 11, 2013 | 11:30 AM
kbracing96's Avatar
Set your commanded AFR to 14.68 and it will use short term trims to keep the part throttle AFR in check. Could even throw a little lean cruze in there if you wanted. I've messed with it and really didn't find any significant gains. 15.5 seemed about the best, any more and I'd loose enough power from it that MPG got worse.
Old Jan 11, 2013 | 11:37 AM
chevrolet all the way's Avatar
i cruise around 14.9-15.0 high 30 timing and get 20-21mpg cruising. mye idc is 5% with a 60psi base and i run no narrowbands
Originally Posted by AKlowriderZ71
I think I'm thinking of beer.
Old Jan 11, 2013 | 12:19 PM
BlackGMC's Avatar
Resident Retard
yeah i got the narrow bands hooked up, and running semi closed loop with a little lean cruise plugged in... Trims are not that bad at all. I will see how it goes.
Old Jan 11, 2013 | 12:24 PM
BlackGMC's Avatar
Resident Retard
What gears do you have?
Old Jan 11, 2013 | 12:49 PM
3.42s. that was with a 60e. i just swapped to an 80e so its a slightly higher rpm. dd trim is 29" tire also
Old Jan 11, 2013 | 01:05 PM
BlackGMC's Avatar
Resident Retard
yeah i have 4.10s swapping to 3.42s in a few weeks.
Old Jan 11, 2013 | 01:08 PM
im very pleased with drivability of the 3.42s. put in the 80e last week with a stock converter so its a big *** turd. im still anxious to feel the new ratios haha
Old Jan 11, 2013 | 02:29 PM
BlackGMC's Avatar
Resident Retard
I love my 80. Do yourself a favor and get the pro yank multi disk 3200. I drove mine several months NA and it was great. Even better with boost!
