Pro Flo XT fuel setup
I got my fuel pretty much setup for the intake. I thought I would share some pics. -10AN feed line, split to -8AN feeding into the back of each rail, out the front of the rails to the regulator, and -8AN return to the tank. The only thing that is not installed in the pics is the return line. I think I might have to change the -10AN fitting to a 90 degree. I think I have the shortest piece for hose in the world referencing my FPR. I'm still not 100% sure on my supply. After what Atomic noted I think I may go with twin Walbro 400's with one on a Hobbs switch.
Thanks for the compliments.
Just 4 feet of rail I got off of eBay. I machined 10 degree notches in them every 4.40" . Then I drilled them 4.40" at 10 degrees. I welded tabs on the bottom so I could run Allen headed bolts through them.
I just drilled holes for the mounting bracket, and tapped them. It is more secure than I thought it would be.
