Nnbs return fuel system wiring fpcm
#63
What’s unplugged? If you have a tester test the voltage when truck is on. If you got 12v then put the fuse tap there and hook both to it. No problem since it’s just a trigger source on/off. You have two separate relays for each pump run in parallel back to the tank?
#64
I have sensors for O2’s, maf, alternator stuff like that.
yes I have two separate relay kits, the ones I posted earlier.
one to each pump, one with an intermediate HOBBS switch to turn on the second pump
#65
Yea you can hook the battery up and check voltage no problem. How far are you from startup and testing? Any pics of you fuel bucket setup? Are you just resting the pumps in the bucket or tie them down?
#66
I also have a water Cooler pump I want to test before I install and run wires.
would it be okay to just run a positive and negative wires to my battery to test, or could I burn it out by doing that?
i just don’t know of a way to check it before I install it
#67
Well if you do that then you wouldn’t know if it get triggered from your ignition source. That’s just hot wiring it straight to positive negative so you would get voltage but you wouldn’t know if it’s on when your key is on. Just plug the fuse block back onto the battery and the turn the key to the acc/on position without starting it and see if that fuse slot has 12v. If you don’t have a tester then I’d buy one. But maybe I’m not understanding what you’re trying to “test”. You trying to test you pumps or the fuse slot where you want to tie the trigger source into? Thought you wanted to see if the empty “fuel pump” fuse slot is 12v? That would need to be tested while the ignition in your truck is in the on position. Unless I’m confused by what you’re asking?
#69
No I’m trying to test the pump for my water pump going to the heat exchanger.
i got my fuel pump relay issue worked out.
the cables coming to the water pump are both black, so I wanted to test to see which is power and which is ground, that’s why I was curious if I could put the wires straight to the battery or do I run the risk of blowing it. I just need to figure which of the two wires going to my pump are power and ground, unless you have a better method
#70
You’re supercharged then. Don’t know much about those but should be able to just put it on the terminals and see if it’s works or not. Won’t blow anything it would just not work if it’s hooked up wrong. Then if it doesn’t work swap it and see if that makes it work. But if they’re not labeled which is which then it probably doesn’t matter the polarity if they weren’t labeled already. Maybe one wire has a white stripe on it?
